You are here: Home > Overview > Supported Devices > Supported Switch Platforms
Central uses the SSLSecure Sockets Layer. SSL is a computer networking protocol for securing connections between network application clients and servers over the Internet. certificate by GeoTrust Certificate Authority for device termination and web servicesWeb services allow businesses to share and process data programmatically. Developers who want to provide integrated applications can use the API to programmatically perform actions that would otherwise require manual operation of the user interface.. As the SSLSecure Sockets Layer. SSL is a computer networking protocol for securing connections between network application clients and servers over the Internet. certificate is about to expire, Aruba is replacing it with a new certificate from another trusted Certificate Authority. During the certificate upgrade window, all devices managed by Central will be disconnected. After the upgrade, the devices reconnect to Central and resume their services with Central. However, for Aruba switches to reconnect to Central after the certificate upgrade, you must ensure that the switches are upgraded to the recommended software version listed in Table 1.
Table 1 and Table 2 list the switch platforms, corresponding software versions supported in Central, and switch stacking details.
Table 1: Supported Aruba Switch Series, Software Versions, and Switch Stacking
Switch Platform
Supported Software Versions
Recommended Software Versions
Switch Stacking Support
Aruba 2530 Switch Series
YA/YB.16.05.0008 or later
N/A
Aruba 2540 Switch Series
YC.16.03.0004 or later
YC.16.05.0007 or later
N/A
Aruba 2920 Switch Series
WB.16.03.0004 or later
WB.16.05.0007 or later
Yes
Switch Software Dependency: WB.16.04.0008 or later
Aruba 2930F Switch Series
WC.16.03.0004 or later
WC.16.05.0007 or later
Yes
Switch Software Dependency: WC.16.07.0002
Aruba 2930M Switch Series
WC.16.04.0008 or later
Yes
Switch Software Dependency: WC.16.06.0006
Aruba 3810 Switch Series
KB.16.03.0004 or later
KB.16.05.0007 or later
Yes
Switch Software Dependency: KB.16.07.0002
Aruba 5400R Switch Series
KB.16.04.0008 or later
Yes
Switch Software Dependency: KB.16.06.0008
Table 2: Supported Aruba Mobility Access Switch Series and Software Versions
S1500-12P
S1500-24P
S2500-24P
S3500-24T
ArubaOS 7.3.2.6
ArubaOS 7.4.0.3
ArubaOS 7.4.0.4
ArubaOS 7.4.0.5
ArubaOS 7.4.0.6
Provisioning and configuration of Aruba 5400R Switch Series and switch stacks is supported only through configuration templates.
